  • 393 Views
RV77
How do I fix this motion dilemma only detects from 4 feet only should be 12 to 15 feet. Motion should be recording.
Make sure the camera is viewing only the needed area rather than a wide view. Have you checked your motion sensitivity setting in the camera settings under Default Mode Settings? Is the motion across the FOV or directly at the camera? A screenshot of the camera view may help.
https://kb.arlo.com/37/Arlo-Camera-Placement-Tips
https://kb.arlo.com/1015583/How-do-I-optimize-motion-detection-for-my-Arlo-camera
RV77
Re: Arlo gen 2 VMC 3050 only picking up motion at 4ft or less, should be picking up at 12-15 ft, fix
A screenshot of the camera's view could be useful. Also, is that 4 foot distance between the subject and the camera rather than the subject horizontally to the wall the camera is mounted on?
