- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- How to remove an Arlo Essential Solar camera (outd...
How to remove an Arlo Essential Solar camera (outdoor) 2nd generation from it's mount
Hi. I need to take down my Arlo Essential Solar panel camera. It has charged down and I need to recharge it. All the instructions I find say to turn the camera counterclockwise and align the small notch on device and tab on mount together, then push in and turn counter clock wise to get the camera off the mount. Problem is. I have no small notch or tab. It's a smooth base and I am at a loss as to how to remove my camera. This has been a frustrating experience for me. Any help would be appreciated very much!
You should see a triangle somewhere on the edge of the base. When you find it, slide the camera+base in that direction. It should lift off.
If that doesn't work for you, just twist the entire camera to unscrew the base from the camera. Then you will be able to remove the base from the part that is attached to the wall, and then screw it all back together indoors.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
