- English
- Cameras
- Arlo Essential Indoor Camera
- Re: essential indoor cam cannot connect to base st...
I am currently using arlo pro 2 with base station and I bought a essential indoor cam which is functioning well when connecting to wifi directly.
However, when I try to connect my essential cam to the base station, it fails and said no arlo derive could be found.
Please help.
Did you remove it from your account before trying to connect it to your base?
Do you actually have the VMB4000 base (which is what you selected for model)?
I'm asking because VMB3xxx bases aren't compatible with the essential cameras. https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
my base model is vmb4500, and I have removed already the essential cam from my arlo account but the base still cannot connect to my cam.
Maybe try the reset procedure for the camera (skipping the remove device step): https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
There's 2 things here - a reset or onboarding. The reset may require a >15 second press but onboarding should just needs a brief press - holding it may cause problems. The instructions say to press it for one second.
I have pressed sync button for a sec after reset to factory setting
but it can still connect to the base station
What is the base showing when trying to pair?
joeyeung,
From your description it sounds like the issue is the camera has not successfully been factory reset. Make sure to charge the camera first and then attempt the factory reset as described in the reset article: https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
Do you still experience the same behavior?
Arlo Essential
Arlo Video Doorbell
