essential indoor cam cannot connect to base station
  • 12 Replies
  • 4157 Views
joeyeung
Hi experts,
I am currently using arlo pro 2 with base station and I bought a essential indoor cam which is functioning well when connecting to wifi directly.
However, when I try to connect my essential cam to the base station, it fails and said no arlo derive could be found.
Please help.
joeyeung
It works and thanks so much for your help.
12 REPLIES 12
Did you remove it from your account before trying to connect it to your base?
Do you actually have the VMB4000 base (which is what you selected for model)?
I'm asking because VMB3xxx bases aren't compatible with the essential cameras. https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
joeyeung
Hi both,
my base model is vmb4500, and I have removed already the essential cam from my arlo account but the base still cannot connect to my cam.
Maybe try the reset procedure for the camera (skipping the remove device step): https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
joeyeung
I have pressed the sync button for 15 sec and 20 sec, but there was no a blinking amber light and the connection was failed.
There's 2 things here - a reset or onboarding. The reset may require a >15 second press but onboarding should just needs a brief press - holding it may cause problems. The instructions say to press it for one second.
joeyeung
What I mean was for the factory setting (15 and 20 sec) only.
I have pressed sync button for a sec after reset to factory setting
but it can still connect to the base station
joeyeung
Experts, anything I can do?
What is the base showing when trying to pair?
joeyeung
when having a pairing, the base was showing a blue light as normal, while the cam showed a blinking blue light and turned to blinking amber light when it was failure.
joeyeung,
From your description it sounds like the issue is the camera has not successfully been factory reset. Make sure to charge the camera first and then attempt the factory reset as described in the reset article: https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
Do you still experience the same behavior?
joeyeung
  • 12 Replies
  • 4158 Views
