- English
- Cameras
- Arlo Essential Indoor 2nd Gen
- Re: Introducing Arlo Essential Indoor Camera - 2nd...
Introducing the 2nd generation of the Essential camera, now offered in both 2K and HD options. Experience exceptional smart home security with unbeatable value and price. We all deserve protection, no matter what your budget is or the size of your property. Choose from 2K or HD camera options for round-the-clock protection.
Privacy on demand. Protection on command. Essential Indoor Camera provides smart home security with an automated privacy shield to protect your privacy too. Offering clear HD 1080P resolution, Night Vision, and Integrated Siren, check-in on your home, family or pets anytime.
Privacy on demand. Protection on command with crystal-clear details. Essential Indoor Camera provides enhanced smart home security with an automated privacy shield to protect your privacy too. Offering crystal clear 2K resolution, Night Vision, and Integrated Siren, check-in on your home, family or pets.
Post a reply or visit Arlo Support if you have any additional questions or need more information about the Arlo Essential Indoor Camera - 2nd Generation
Thank you for being part of the Arlo Community!
Can this be used with an existing VMB5000 base station like the legacy (current) Indoor Essential camera?
It wil only be able to connect to WiFi when released - that's happened before. A firmware update will be needed down the road to allow connection to a hub.
Appreciate the response. That was my concern as well.
Is there a user manual for VMC3060 (Gen 2)? (Not the quick start guide) Thx.
Lisa77,
You can find manuals for Arlo cameras in the documents library here: https://www.arlo.com/en-us/support/docs
The manual for VMC3060 is not yet available but we expect it to be finished soon.
i have 3 of these cameras and when they wont connect or work. keep getting a error zero code. crazy that they put these out and they don't even work. right now i have three new paper weights. thanks Arlo. called support many times and they say well everyone is having this issue. sorry that's a good solution to my problem. I don't think they know what to do. I just wish my cameras would work. I know tons of people that bought this recently and everyone is having the same issue. Waiting on a response to see how to proceed or if I have to throw them away and buy something that actually work. I really thought Arlo would be a good purchase. Is any one else having this same issue with the essential camera gen 2.
bartcannady,
We're currently investigating reports from some users experiencing issues onboarding new devices. For more information and updates, see here: https://status.arlo.com/
When will the Gen 2 Essential Indoor camera be available in Europe?
PaulGr,
Keep an eye on https://www.arlo.com/en_eu/home
Once available an announcement will be made there.
Can I use this in Hong Kong and UK?
I try to pair it via the Arlo secure app but not able to find the 2nd generation cam.
Tomlo,
Arlo Essential 2nd generation products are not available and cannot be onboarded in Hong Kong/UK at this time.
I can't tell if this 2nd generation indoor camera can stand on their own without a mount? The pictures don't really show a clear view of the bottom of the cameras. I have the Arlo - Essential Spotlight first gen and I can just set them wherever indoors. Do 2nd generation have a flat spot that they can stand on their own?
(hint, maybe update the product details page with a few more pictures?)
Thanks!
George
gpeden,
Yes. The camera can sit flat on the charging port and stand on it's own. This limits the angle in which the camera can be positioned and the camera wouldn't be able to have a charging cable attached, but is possible if it makes sense for your use case.
I have the same problem!!!
I have the same problem.
ok I ended up going with the 2k camera because it was obvious from the pictures that it would work the way I want.
It seems you might be making an assumption that users will have these camera permanently installed/mounted? That isn't how we use our cameras so being able to have the cameras free stand without a mount is important.
g
Why is CVR not supported?
CVR is not available for all Arlo devices due to software and hardware limitations with specific models. For more information on CVR and what cameras are supported, see here: https://kb.arlo.com/1018425/What-is-continuous-video-recording-CVR-and-how-do-I-use-it
Complete non-answer.
CVR is supported on first Gen indoor essential. So it should be supported in second Gen, and support actually says the dev team is "working on it".
Can the Arlo indoor camera (2nd generation) connect to the Arlo hub (model: VMB4540)? If it is not available yet, is there an expected schedule? Thank you
Not yet available, no known schedule.
Any update on if and when we will have the firmeware update to connect the essential indoor gen 2 cameras to the SmartHub for HomeKit compatibility? This is one of the main reasons I bought this product and did not realize the second gen cameras will not connect to the SmartHub.
The documentation says to add this as Arlo Essential Indoor Caerma - 2nd Gen; this is not an option for the app; it still lists only the original cams, and this one will not 'chime' on the QRS code with any of my 2.4mhz routers picking the essential series cam.
What country are you in?
The camera isn't available in all geographies yet (and the app won't show it as an option in those areas).
Arlo Cameras
audio
battery
Cable
Cord
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
