Baby room
1.8.0.25_12698 Firmware version
ABC1000r6 Hardware
Hi @kungFuPanda,
A new firmware version 1.8.0.27_12874 was released last night (May 21) and should address the night vision issue you are experiencing. The firmware should have already been uploaded onto your camera. Have you had a chance to use the camera today? If yes, are you still seeing the issue?
Thanks,
Tu
check and make sure the IR illuminators are on
kungFuPanda,
The Arlo Baby IR LED is very difficult to see, which may appear at first to not be working. Test a live stream at night to see if Night Vision is working.
Had a dim night light in one corner of the camera's point of view and appeared to have thrown off the sensors.
I'd open a case with Netgear so you have a record. take screenshots of IR "off" and IR "on" in the darkest room, closet etc. The difference should be night at day....
Night #2 without night vision working. What is the issue? It has not worked since I received it. All there is is a pitch-black screen.
Also, in terms of setting motion zones up, it will not update to where I eventually moved the Arlo Baby. It has kept the same screen grab from when I first turned the Arlo Baby on. Why is this?
ChicagoOutfit,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Hi @kungFuPanda,
Thanks,
Tu
You guys can't even get an update out right? Mine is saying no update available. Still says 1.8.025.
dc2,
Consider restarting the camera. Log in to your Arlo account and navigate to Settings > My Devices > select Arlo Baby > Device Settings > Restart. Allow the camera to come back online and try again. Are you still seeing the same behavior?
Will be able to test this more when I get in from work.
Arlo Baby
