Is there a way to disable notifications on my phone only when I'm not home?
  • 1 Reply
  • 990 Views
Benjiruss
Is there a way to disable notifications on my phone only when I'm not home. I tried using geofencing but it turns off the cameras notifications all together so even my partner who is home doesn't get them.
JessicaP
Hi Benjiruss,
When you're referring to notifications, are you referring to motion/audio detection notification or Geofencing status notification?
