  • 7 Replies
  • 2038 Views
Saveta
Hello, My Arlo Baby ABC1000 will not find the device (on my mobile or web log in). It chimes and then it wont proceed from the next step where it says find device. It continues to say device not found. I have also turned off my mobile date and ensured all devices are on the same internet. Please help ? I have an android phone.
7 REPLIES 7
JessicaP
Hi Saveta,
Make sure when you're inputting your WiFi SSID and password correctly as characters are case-sensitive for both.
rmonge1152
I have had the same issues with my baby Arlo monitor for the last 6-7 months I’m at the point where I’m gonna call it quits. I’m bummed since I have my Arlo pro cameras which are great.
Saveta
HELLO. all the information has been inputted correctly and still no luck....
rmonge1152
I have done all of the above and it is the baby camera.
Have you tried a full reset of the Baby?
( hold in reset till led flashes amber ) then try to sync as if new.
PS... don't forget there is a switch under feet to turn off battery if you need to unpower it
rmonge1152
All of the above. As well as had a new router and modem installed. The baby monitor looses connection at least 6-7 times per day and with a child with medical issues it’s very disconcerting
JessicaP
If you're still having problems, please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 7 Replies
  • 2039 Views
