It sits 5m from my wifi router. My whole house has smart devices and streaming devices. None complaining both the network and internet are fast in every corner of the house.
Will be returning this first thing next week unless anybody here knows of any quirks that I am not aware.
Wondering if the issue started with the latest firmware update...
Don't need to drain the power... there is a switch for the battery under the feet.
But have you done a full reset? Hold in reset for about 10 secs till the front led flashes and then resync as if new.
Tried also with it running on a 2.4Ghz and 5Ghz wifi links and both had similar results. The camera works for a couple of hours then it disconnects and will never reconnect again.
acaus,
This sounds like it could be an issue with the Arlo Baby device. I encourage you to contact and open a case with the Arlo Support Team to further investigate the issue.
Alex99,
Can you give more detail about what you are experiencing? Are you seeing an error message in your Arlo app or are you seeing an amber LED as described in the original post here? What are you doing when you experience an issue?
It’s an amber flashing light. It just says it can’t find the camera. I had it connected for an afternoon and since then it won’t find it. I get right up to the QR code it chimes and then nothing! I’m really getting over this product and am telling everyone of the issues as looking in the community it doesn’t look like it’s just me!
Alex99,
A flashing amber light means it's not connected to your router. Did you remove the camera from your Arlo account? If so, try factory resetting and then go through the claiming process again to see if you experience the same results.
How do I reset Arlo Baby to factory default settings?
I have also tried turning on/off my internet and phone.
This is ridiculous! It worked for an afternoon then changed it’s mind!
Alex99,
When logging in to your Arlo account is anything present under Settings > My Devices?
Alex99,
Okay, so as long as you've completed the factory reset you should be able to claim the camera again. Do you have a computer that is connected to the same network that you could try going through the claiming process with?
Alex99,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Arlo Baby
