I updated my arlo baby and the ios app (ios12) and still have the pixelation in the live view - also i have the sound problem in my app that is described in other threads.
Do i have to reset my arlo baby or is there anything i can do? I´m disappointed that the issue still is not fixed.
Hi
Is any one aware of the bug with live streaming picture over WiFi. As soon as you outside your home over the mobile network the problem with bad live-streams picture disappear. The problem have been going on for a while now.
I have the newest iPhone app, firmware on baby 1.9.13.0_815 and really god WiFi and Fiber connection with just 4 ms delay. The Arlo baby is just 3 meter from the router. It blurry especially in the bottom, and the blurryness is jumping around.
Hi @Sematwir
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
I tried:
Reset/Reinstallation
Change of WiFi Hz
Change of router
The access is 100/100 Mbit/s fiber with just 4,4 ms.
Have your tried to find the bug?
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Can you give me a direct link to tech second line support?
I changed the camera and bought a new one. Of some reason I did get the same HW 6 even if my older camera also had that.
First it worked fine. But, After all upgrades that was pushed the problem also occurred on this new one. So with you buggy firmware I also now have the same problem on the new device!
There is a bug in the firmware or it do not work with the Hw version 6!! Can you please send me an device that have HW7 or later please?
Do you have a screenshot of the blurry image you are reporting?
It is a bit hard to get them on a picture because it coming and going. It often more then this pictures. Maybe I can get a more detailed picture tomorrow, but I think you the problem already?
Don’t expect a resolution. This will never be fixed. Live with it or buy a different brand
I don’t accept that Netgear/Arlo-support can be that bad?
It worked fine before the last update in the camera..
Five posts, zero solutions. #netgear
Hi @David30
Is this occurring over Wi-Fi or data or both? Do you happen to have a screenshot of this pixelation you can provide?
Does the pixelation occur when you're on the web portal?
To anyone who comes here looking for support on this issue, I’ll give you the harsh advice: don’t waste time corresponding with Netgear on this. They have abandoned this failed product.
Arlo Baby
