Hello.
I’m having the following issue with my Arlo Baby camera: the temperature sensor is giving an inaccurate measure (+ 2 Celsius degrees). I installed 2 additional thermometers next to the camera, and both of them show the same temperature that is 2 degrees less.
How can I fix this?
Thank you.
How can I fix this?
Thank you.
Best answers
To recalibrate your Arlo Baby’s sensors:
- Unplug the USB cable from your Arlo Baby camera.
- Rotate the foot plate and remove the Arlo Baby character’s feet.
- Slide the battery switch on the bottom of Arlo Baby to off.
The battery is turned off when no green is visible near the battery switch. - Wait ten seconds, then slide the battery switch to on.
Your Arlo Baby camera restarts. - Replace the foot plate and rotate until it clicks into place.
- Plug the USB cable back in.
Your Arlo Baby’s sensors recalibrate over the next 24 hours. - If you are still receiving too many alerts, change your notification settings and alert thresholds from the Devices tab of the Arlo app.
For more information about changing sensor settings, see How do I customize Arlo Baby’s sensor settings for temperature, humidity, and air quality?.
Arlo Baby
