  • 6 Replies
  • 14655 Views
HannahS
The buttons for Arlo Baby do not work on the Android app, the light button is greyed out and the music button is just blank. Both buttons work on the ios app so why does the Android app not work? It makes the monitor fairly useless for anything more than a camera. Running Android v.11 and there are no updates to the app available in the play store. Does Android app actually work for anyone?
6 REPLIES 6
Have you rebooted the phone and reinstalled the app?
HannahS
Yes, tried that but the buttons are the same.
JessicaP
Hi HannahS,
Have you tried checking to see if it works when you're on WiFi and/or cellular data? Could you provide two screenshots from both your Android device and your iOS device?
hmurphy
I've had the same issue for months now. I've reinstalled the app and restarted my phone. I've tried WiFi and cellular data. Nothing works. See screenshot.
You'll notice there's an orange dot next to my settings button, but it doesn't lead me to any setting that I need to look at.
My wife's phone still works fine though.
JessicaP
Hi hmurphy,
From looking at your screenshot, are you the main account holder or the grant access holder? If you're the grant access holder, make sure that the main account holder gives you "Allow Access Rights" enabled for your account. You can read here to learn how to enable it: How do I edit my friend's privileges in my Arlo account?
hmurphy
Good news is that the problem is solved. My wife is the main account holder and my phone was already granted access rights. I got her to turn it off, close the app, reopen the app and then turn on my access rights again and that fixed it. I can now check what temperature the room is etc.
  • 6 Replies
  • 14656 Views
