Arlo Baby LED blinking at night
- Email to a Friend
The LED blinks still. The post about the LED problem being solved and unable to post in is bull **bleep**. It’s not solved. I have taken the camera down to avoid having it wake my child up again. PLUS I still get notifications about random strangers needing their base station token reset. I can not recommend the product to anyone
- Email to a Friend
- Email to a Friend
Hi @jdg710
Thank you for the detailed information. It sounds like your camera may be losing connection to your router. A blinking blue LED means the camera is attempting to connect to the Internet. If your Arlo Baby is connected to your WiFi network but has a poor connection to your router, the LED blinks purple. As your camera is offline, I am not able to perform diagnostics. If possible can you plug your camera in for further investigation. additionally I do have a few questions for you:
- May I ask which firmware your Arlo baby has installed? The latest Firmware (ABC1000 - 1.9.15.0_817) addressed this issue.
- When did this issue first occur?
Arlo Baby
