Arlo Baby Timezone changing by itself
I have 3 Arlo Baby's all with exactly the same settings, but one of them keeps changing the timezone from +2 to +3 by itself. I tried resetting it to the correct timezone using the web interface and mobile app multiple times. Everytime it seems to be ok for a day or two and then it again reverts back to the wrong timezone. The other 2 Arlo Baby's do not have that issue.
Which version of the Arlo app are you currently using?
4.1 (5991)
Have you tried a factory reset on the baby camera?
Yes I did. Factory Reset, firmware update - all basic troubleshooting done. Still the issue continues.
Thanks for the update, I will provide more info as soon as possible.
I just wanted to check if you were able to find a solution for this.
This is being investigated and I will be sure to provide an update as soon as I can.
Ok. Thanks.
The team is still investigating this issue.
Thanks for following up on this. Since the last app update, I've been viewing the time zone to see if the problem happens again. Normally it was happening every couple of days or latest after a week of correcting it. It's been almost 1.5 weeks and so far it seems to be stable. I will keep on monitoring for some more time to make sure it is fixed for good.
Arlo Baby
