  • 7 Replies
  • 1851 Views
Scotte2010
For the life of me I cannot locate my Arlo baby when trying to connect. It worked fine for months then one night just disconnected and we haven’t been able to get it back on since. Resetting via reset button does nothing.
Amber light flashes, but then goes off and the White Back light comes on. This happens on loop.
When connecting I hear the chime when doing it by QR Code but then it can’t locate the camera. Can’t locate on Apple home either. Any ideas before it goes in the bin?
7 REPLIES 7
Make sure you hold the reset for about 10 secs.... till the front LED flashes amber
Also don't forget to turn off battery switch under feet for a few secs after unpowering
Scotte2010
Appreciate your response but I’ve held the reset button for 10 seconds on multiple times and yesterday was the first time the Arlo was powered up in about 8 weeks.
But did the front LED flash amber on reset ??
Scotte2010
No, nothing happened. The process continues amber light then back white light.
During a reset of holding down button for 10 secs or more, the front led will flash amber... if it doesn’t, then it hasn’t reset.
From what you described, it may be a hardware issue
Scotte2010
Yeah, holding down reset does nothing. Any advice on what to do if it is hardware related? The camera is less than 12 months old.
There is a 1 year warranty on  Arlo products TMK...
contact support for a warranty issue here :  https://www.arlo.com/en-us/support/contact.aspx
( under open a case )
  • 7 Replies
  • 1852 Views
