So I've had the Arlo Baby for some time now (long enough that it can't be returned ) and I'm still running into issues with screen pixelation. I've followed the troubleshooting guidelines provided by Netgear and turned the Bluetooth on my iPad off and also have both the IPad and Camera on a 5Ghz channel (it was horrendous before turning th Bluetooth off). The camera is in a room directly below the router's location (Netgear R7000). I've provided a picture to help clarify what I'm talking about. Maybe I'm expecting too much but for the cost, I'd expect a 1080p camera to look a little better.
Try it on the 2.4GHz network
CHUD2,
Adding to steve_t's suggestion above, do you also see this behavior if you move the camera to the same room as the router? Try this temporarily to see if you get the same results.
Arlo Baby
