No, it's not normal. Try resetting the camera and resync. If it's still there, turn off audio to test. It could be feedback so repositioning the camera and/or changing audio settings may help. Otherwise, swap at the store or open a case with support.
Thanks for the response. I tried moving it to different places, on and off the device and still have this sound.
Here's a link to the high pitch sound I am hearing from the Arlo Baby:
Fairlady,
The link you provided doesn't seem to be a specific example of what you are experiencing with your device.
If your Arlo Baby is producing a sound similar to what can be heard in the link you provided, this isn't normal behavior. Consider contacting the Arlo Support Team for further investigation of the issue.
