Arlo Baby Getting Status
My Arlo baby is showing Getting Status... when i am accessing from outside(every few times worked)
But works fine when connects to same wifi network in home.
This is not solving my purpose at all.. as i need to watch my Baby when i am at work not when I'm in home
Any suggestion and setting.
Reset is not a solution everytime
What phone and OS are you using to access.... it may be OS and/or phone specific .
( the new iOS 11 has had a few issues )
Can you try and access on a different phone and also access via the web to assure the system is working normally.
iOS 11 (iPhoneX)
but i dont think its OS issue as its working fine when i am in home on same wifi network
bhanu,
Are you connected to your mobile data or your work network when at work? It sounds like your work network could be blocking the stream.
Arlo Baby
