Tried to pair Chime with Smart hub after all the most recent updates. No luck. Tried at least 10 times. Chime was recognized once but paired Doorbell was not able to trigger it to play the signal. So I removed the he Chime, reset it and tried again and again. Was not successful. Tried to pair it to Arlo Pro 2 hub - happened right away. Removed it, reset it and tried again pairing with Ultra Smart hub. Could not do it. 5 times.
Of course I still have the issue with the paired to Doorbell camera not showing image (it’s all grey) when someone rings the Doorbell and I accept the call on my phone. Use to work 4 months ago. Hopefully it’s going to be fixed soon.
Thank you for all the help!
Hi @Jorro,
At what step does your Arlo Chime fail when trying to pair it to your SmartHub? It might be that you have not removed your Arlo Chime from your Arlo Pro Base Station.
When you try to pair your Arlo Chime with the Arlo SmartHub, does it list your Arlo Chime? Or does it not show at all?
I ended up pairing them both back with Arlo Pro 2 hub. Waiting for the next Smarthub firmware.
I can vouch for the chime pairing with the Ultra base. How were you trying to do this? The last firmware update this past weekend enabled it.
How did you do it?
I have all the most recent updates and tried about 20 times. Doorbell paired immediately, but was told - no full functionality.
Chime - not at all with Ultra hub. (Chime pairs immediately with arlo pro hub - no problems)
My chime synced immediately. I had to remove it from my Pro base, unplug it and plug it back in. I've done it a couple of time - one time I may have had to use the sync button on the chime - I forget for sure.
Well, I have no idea why I have had all the problems and it is still not working for me.
Just to let you know, the Arlo SmartHub fully supports Doorbell and Chime. I have sent you a private message to gather some information from you. Hope to hear from you soon.
So, what should I do ? I need a Chime replacement.
First, what firmware is on your Ultra base? You need the latest to have the doorbell and chime to work. Mine is on 1.12.1.6_32471 which works fine.
If it's really bad hardware, either swap at the store or open a case with support since that's the only way to invoke your warranty:
It didn't work. I am currently working with an Arlo representative and hopefully it will be resolved soon.
Thank you for your input on my case!
