Normal for back to only have rubber weather seal on just one of the screws for Audio Doorbell?
  • 4 Replies
  • 3025 Views
FuzzyWolf
Hey guys,
I just got an arlo audio doorbell and was wonder if it’s normal for the back where you screw it into the wall to only have like a rubber weather seal like things on just one of the screws? Because mine only had them on and seemed like its suppose to have two.
@FuzzyWolf wrote:
Nope theyre like grey o-rings
Ok.  I just checked my doorbell, and it has two.
I suggest exchanging it with the seller.
Do you mean the anchors shown on page 4 here: https://www.arlo.com/en-us/images/Documents/ArloAudioDoorbell/arlo-doorbell-installguide.pdf ?
They aren't weather seals.  You'd only need them if you are installing the doorbell into wallboard, concrete, or brick.
FuzzyWolf
Nope theyre like grey o-rings rubbery kinda things that is on the hole that the screw go through on the backplate that you screw into the wall.
FuzzyWolf
Thank you very much for your help! I’ll contact amazon for a replacement.
  • 4 Replies
  • 3026 Views
