  • 4728 Views
jordanjd
Is there a way to have the doorbell only alert/send a push notification to the phone when the Arlo System is set to armed? It’s our front door so I don’t want it to push notify when we’re home but I don’t want to it to alert me when we’re home because we come in and out frequently. Thanks!
schumaku
What "function" of the Doorbell are you referencing?
  • Doorbell button pressed ... and you don't want the Doorbell call (resp. under some conditions [mobile device battery low?] just a notification)?
  • Doorbell motion detection?
  • Secondary push button action after the "Press button again to leave a message"?
When disarmed, there are no motion triggered notifications or actions - neither by the Audio Doorbell not by the associated HD Camera.
If you still get motion triggered notifications (and recordings, depends on the settings) while the system is disarmed, you might have Geofencing (or some custom mode) in use check e.g. Mode -> Geofencing -> Select Mode: Home Mode is set to Disarmed (or to an appropriate Schedule).
Only the doorbell button press can trigger the chime, but also always trigger a notification and/or the audio doorbell video phone, regardless of the system (or partial system, the Base Station the Doorbell is connected to) armed/disarmed status.
@jguerdat wrote:
Use the Motion Settings for the doorbell. Select Do Nothing but enable notifications.
This would disable things regardless of the armed or disarmed state IMHO.
Please click on thumbs up if this answer was useful - thank you!
schumaku
No, it simply disables recordings. without at least a notification set, you can't even save the rule since it would basically be the same as the Disarmed mode.
  • 4729 Views
