My doorbell has just stopped ringing my phone, it flicks up for half a second, then drops out. Have reinstalled, changed battery, still the same thing. What have you done Arlo since last update?
6 REPLIES 6
I having the exact same problem, however the doorbell worked fine before I granted access to another person.
Mark001, lavarex2000
The development team is investigating reports of this issue and has taken appropriate action to alleviate the problem. Are you still experiencing this issue now or are calls from your doorbell coming through as expected?
No mine used to work phone, on two phones permissions and access was fine, just since last iOS and change of battery.
Still the same issue, I am not the only one having issues.
Problem fix, doorbell now contacts both phones. Thanks!!
Mark001,
Try restarting your doorbell again by removing and reinserting the batteries. Do you still experience the same behavior?
