How do I change the motion sensitivity on my Arlo Door Bell? It keeps on alerting me several time a day when people walk in front of the house on the side walk 50' away.
10 REPLIES 10
Currently the sensitivity can't be changed.
Retired_Member
Not applicable
2018-12-10
11:31 AM
Just received my doorbell (UK via the US) and shocked to see that this capability is missing for the settings - If it becomes a problem I’ll just put a piece of black tape over the sensor until its sorted - Nice additional capability to my cameras but come on NetGear sort this one out quickly I’d like to reduce this to less than 10 feet.
Retired_Member
Not applicable
2018-12-11
12:16 PM
Yes I do
Retired_Member
Not applicable
2018-12-11
12:17 PM
Sorry return to early. It seems to have settled down and only triggers within 5m.
yes I do
Bummer
Try to adjust the motion sensitivity for your camera to see if that helps (if you have your Arlo Audio Doorbell and cameras linked together). You can view here on how to adjust the motion sensitivity: How do I change the motion sensitivity on my Arlo camera?
Try to disable the cross-triggering and see if it's still sensing motion from 50 feet away with just the Arlo Audio Doorbell itself. Then try to re-pair them again and see if that helps.
