Chime wont sync with base station - Orange/Red Light
  • 2886 Views
mshoebri123
All my cameras are working sync'd fine (ULTRA base station and cameras)
Doorbell sync'd fine
Tring to add the chime has been troublesome.  I have tried factory reset. Even tryed postioning the chime next to base station. But same result after the white flashing lights - it goes orange (or red.) and does not connect.
Any ideas?
It may be faulty. Swap at the store.
mshoebri123
@jguerdat No. Replaced it same problem.
I removed both the chime and the door bell.
Now can't add the door bell either.
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
  • 2887 Views
