Cannot change melody setting when trying to set chime to ring when motion is detected
  • 8 Replies
  • 10742 Views
Kezza1133
I have created a motion setting for the doorbell. I have set the chime to ring when motion is detected. I want to change the melody setting but it won’t let me.
Kezza1133
I reset the chime and all is working
8 REPLIES 8
michaelkenward
Sensei Sensei
Sensei
@Kezza1133 wrote:
.... but it won’t let me.
Can you explain what that means?
You have reached the "Mode" screen that lets you make the change:
"What melody do you want to play?"
and it fails to hold?
Or you don't see the Sound options?
Just another user
Kezza1133
Yes I want to change the melody and it doesn’t hold
michaelkenward
Sensei Sensei
Sensei
I'm sorry. I'm being thick, but what does "it doesn’t hold" mean?
Just another user
Kezza1133
It doesn’t stay on what I choose. It reverts back to the one I currently have
JessicaP
Hi @Kezza1133,
Are you using the Arlo app on your phone or on the web client on your computer to change the melody setting? If you're using the Arlo app, what phone device are you using?
Kezza1133
Apple iPhone XS Max with latest Arlo app
JessicaP
Try going onto the web client on your computer and change your melody setting there to see if that helps. Have you also tried reinstalling the Arlo app and restart your iPhone?
Kezza1133
  • 8 Replies
  • 10743 Views
