  • 7 Replies
  • 6024 Views
  • 2 Likes
  • 5 In Conversation
Retired_Member
Not applicable
When someone rings the doorbell it takes 5 - 10 seconds for the chime to go off and for it to ring my phone. Is anyone else having this problem or have a fix for it? The doorbell is up to date and I’ve removed and re added it back to the smart hub.
7 REPLIES 7
JessicaP
Hi Marra0023,
What is the signal strength for your Arlo Audio Doorbell to your SmartHub? Make sure your Arlo Audio Doorbell, Arlo Chime, and Arlo SmartHub is not far from each other to ensure a stable connection.
Retired_Member
Not applicable
Everything has full strength
JessicaP
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Moodtastic
Hi, did you ever get this resolved. I have a similar problem where there is a 5-10 second delay from button press to ring and phonecall. Everything has great signal strength and within 5m of the base.
Retired_Member
Not applicable
Nope never got it fixed
Adksi11892
I’ve got the same problem although when I first received it and was testing it indoors the chime and call went through instantly so I think the delay is because my driveway and front door cameras trigger as someone arrives and then they press the doorbell.  I’m guessing that the activity from those causes a queue.  Does that apply to you guys as well ?
tkpaul
Same problem here but with video bell–– have contacted Arlo several times and have followed all directions/suggestions.
Have finally been told that the delay IS JUST HOW IT IS and nothing can be done about it.
Delay isn't a bug, it's the system as it is.
  • 7 Replies
  • 6025 Views
  • 2 Likes
  • 5 In Conversation
