My arlo doorbell makes the mechanical bell only sound once or twice when you press it, I tried switching it on 3 modes and works best in position 2, just for two or three times, then it doesnt sound the bell but it does make the call. Every time I turn off the circuit breaker and back on it will work for another 2 or 3 times
Hi Javierrp8,
If you have an existing mechanical chime, make sure the chime switch is on position 2. You can read more about it here: How do I set up my Arlo Audio Doorbell to trigger my existing chime?
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
