Arlo Audio Bell call lasts 5secs
Already reinstalled app and devices ( hub included).
Also gave full permissions to app.
What can I do?
Have you tried to reboot your phone and re-install the Arlo mobile app? Which version of the Arlo app do you have installed? the latest Version is 2.19.
Is this an Android device?
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Additionally, you may use the Arlo help center within the Arlo app. You can find this within Settings > Support
This version was changed again 2 days later on August 27, 2020. 2.19.2-28110.
Arlo still messed up .. constantly negotiating updates at exactly 3 am, 4 am, 5 am each night.
Someone needs to figure out why this is happening and fix it as (auto) notifications are also transmitted at these times and chime settings are triggered.
Thanks for the step by step tutorial. This works really well for us, thank you!
Did you have a fix on this issue? I have the same problem with.
