  • 11 Replies
  • 4178 Views
  • 5 In Conversation
Ptgomes
With no apparent changes, the audio Bell, when pressed, doesn't make the usual sound and the call to my phone hangs up after 3 secs.
Already reinstalled app and devices ( hub included).
Also gave full permissions to app.
What can I do?
11 REPLIES 11
ShayneS
HI @Ptgomes
Are you still experiencing this issue with your doorbell?
Ptgomes
Yes...
ShayneS
Have you tried to reboot your phone and re-install the Arlo mobile app? Which version of the Arlo app do you have installed? the latest Version is 2.19.
Ptgomes
Yes. Version 2.19.1_28105
ShayneS
Is this an Android device?
Ptgomes
Yes
ShayneS
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Additionally, you may use the Arlo help center within the Arlo app. You can find this within Settings > Support
Constant123
This version was changed again 2 days later on August 27, 2020.  2.19.2-28110.
Arlo still messed up .. constantly negotiating updates at exactly 3 am, 4 am, 5 am each night.
Someone needs to figure out why this is happening and fix it as (auto) notifications are also transmitted at these times and chime settings are triggered.
Copeins11
Thanks for the step by step tutorial. This works really well for us, thank you!
Daniel_101
Did you have a fix on this issue? I have the same problem with.
Ptgomes
Not really. I figured that keeping the app opened minimizes the time.
  • 11 Replies
  • 4179 Views
  • 5 In Conversation
