- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- Re: Introducing Arlo Video Doorbell - 2nd Generati...
Introducing the 2nd generation of the Arlo Video Doorbell, now offered in both 2K and HD options. While you’re away from home, running errands, working, or on vacation, you can count on the Arlo Video Doorbell to let you know what’s happening at your front door.
Protect your door and more. Video Doorbell protects your front door with clear HD 1080P resolution, Night Vision, and Integrated Siren. Respond to visitors with 2-way audio or send a quick reply message. · HD Video Doorbell · Updated seamless Bluetooth onboarding · 180° field of view · Built-in battery with new technology for long life · Night Vision · Sleeker form factor with newer battery technology
Protect your door and more with crystal-clear details. Video Doorbell protects your front door with crystal clear 2K resolution, Night Vision, and Integrated Siren. Respond to visitors with 2-way audio or send a quick reply message. · 2K Video Doorbell · Updated seamless Bluetooth onboarding · 180° field of view · Built-in battery with new technology for long life · Night Vision · Sleeker form factor with newer battery technology
Post a reply or visit Arlo Support if you have any additional questions or need more information about the Arlo Video Doorbell - 2nd Generation
Thank you for being part of the Arlo Community!
When will there be a fix for the horrible noise issue making the doorbell essentially useless for its intended use when actually trying to talk to someone at the door.
Hi, I just purchased 2 video doorbells (2k, 2nd G), and the Smarthub VMB4540. Will these work together, or do I need to return them?
The 2nd gen cameras (and doorbells) do not support smarthubs yet. Arlo says they will add that feature, but haven't said when.
Hi. I have exactly the same problem. How you fix it? I have the last version of Arlo Secure in both my iPhone 14 Pro and my iPad and the Video Doorbell 2nd Generation does not appear in the App to start installation.
mrodrigu74,
Where are you located? Arlo Essential 2nd generation devices are not available for onboard in all regions.
Wish I'd have read this first, mine was stole just before I found out my trial was up n didn't get footage of the thieving swine....
@JamesC regarding the local storage capability for the Doorbell 2, is it possible to get on a list to know when its available or do you have any details if it comes this or next year? I assume Arlo has a software/firmware release planning where they list out the features etc. they deliver.
Plus maybe you can check if the local storage videos can ever appear in the Feed section please?
Referring to passages in the Arlo user manual, it can only be connected to 2.4 GHz. Here are the references:
2. Make sure your phone is connected to 2.4 Ghz Wi-Fi network...
6. Select a 2.4GHz Wi-Fi network.
When you install and set up your doorbell, the Arlo Secure App guides you through the
process of connecting the doorbell to your router’s 2.4 GHz Wi-Fi network.
You can change your doorbell’s Wi-Fi to a different 2.4GHz Wi-Fi network.
Hope that helps.
2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
intermittent
Mechanical chime
no app model
noise
Phonecall
Secure Plus plan
Secure Trial Active
speaker
Talk
wired
Wmb4540
