I have smart things at home, and would love to somehow be able to integrate the camera and motion detection to smart things to trigger other actions or alerts. Any plans of having any sort of integration?
Good morning juanmlopez23,
Thank you for your inquiry! The Arlo team is currently working on multiple partnerships. We will be sure to post an announcement in the Arlo community once any new third-party device integration becomes available.
Best Regards,
Christine
Arlo Team
____
Please click
KUDOS or REPLY if you found this helpful.
Hi Christine, just thought I'd check in on whether there's a SmartThings integration in the works yet?
Thanks,
Brandon
There are things coming down the pike... all secret of course. You just have to wait.
But , TECHHIVE had a review and popped this out last month;
"Netgear is participating in AllSeen, the video splinter of the smart-home AllJoyn movement. To that end, you should be able to eventually use the hub to open gates, feed the cat, walk the dog… Seriously, the company is already working with LiFX so the unit can turn on that company’s lights. Of course there are dumb systems that do that already, but what the heck. You can see the alert and turn the lights off if it’s a false alarm."
(allseen is an open arch for interoperable peer connectivity... (let electronic things talk to each other ))
(Lifx btw, works on low power IPv6 802.15.4 mesh network)
TriggerTact wrote:
snip... If so, then is Netgear interested in it so it can eventually integrate it's smart home products (Arlo) to other smart home hubs (SmartThings) and devices?
I would take a simple guess and say Yes...
Please add integration with InControlHA.
Any new updates here? I just purchased an Arlo and love it. However, it needs to be integrated to work best. Thanks!!!
Other things to note about the launch are that several new devices and products will be supported by SmartThings, such as Chamberlain garage doors, Honeywell Thermostats, Nest Thermostats, Philips Hue lights, Netgear products, August locks, the previously announced Samsung appliances and new apps for the Gear S and Samsung Smart TVs.
This would be awesome. I love to only have to manage/view one app instead of two.
For me ST integration is key to aquire any alro cam. I am specifically waiting for this integration to get into ST as the current compatible cams are either too expensive (Samsung and Nest) or poorly rated (D-Link).
The most important thing is that they work with the ZWave protocol, as most Smart Home products use that the most. SmartThings is only the hub/controller, though it does play a big part. Which there are many types already out there.
The best hub/controllers work with multiple protocols, ZWave, Dlink, Std Wireless, zigbee, just to name a few, with ZWave being the most prevalent!
If Netgear locks themself to a propietary protocol, there will be many Smart Home users, who are in the know, that will just bypass their product. As more and more people are now jumping into the Smart Home arena, they will find out that your Smart Home Security just does not revolve around a wireless camera. It is group of products, made by different manufacturers, that may or may not speak the same protocol but will be brought together with a hub/controller to make things easier for the end user.
Netgear make it compatible with ZWave and you probably will see more of your wireless cameras fly off the shelf.
geotrouvetout67 wrote:For me ST integration is key to aquire any alro cam. I am specifically waiting for this integration to get into ST as the current compatible cams are either too expensive (Samsung and Nest) or poorly rated (D-Link).
zwave would be nice but it does not have to be to work with ST, the D-Link cams that work with ST are not Zwave and I don't think the Samsung and Nest cams are either.
I think you are misunderstanding. You're right it does not need to be ZWave, but if you look at many of the products that ST sells, many use the ZWave protocol.
Many things are branded with different names, what you find to be made by ST, in fact may be a GE or a Jasco. You really want ST to talk to everything especially ZWave as you will find that Zwave products are more in abundance than just your Samsung and Nest Cams.
For instance ST connects to the following.
Schlage doorlocks - ZWave
GE/Jasco Light Switches - ZWave
Motion Detectors - ZWave
Window Sensors - ZWave
Honeywell Thermostats - ZWave
Again this is just touching the tip of all the ZWave products out there and guess what your ST hub/controller can speak to all of it. Why limit yourself to just Samsung, Nest, when you can have it all. Don't let the product limit you with what you can do with your Smart Home. Think Smarter not Harder and work less!
My brother sets up ST systems for many homes, so I know what they can do. I use InControl, basically all the same, just different when programming. You can do practically do everything now with speech or a touch of a button and thanks to ZWave, Zigbee and all those other products out there, we have a smorgasborg of products to choose from.
Oh in closing, Nest protocol is Std wireless, everything can be made to talk with that, which both ST and InControl do well with it.
geotrouvetout67 wrote:zwave would be nice but it does not have to be to work with ST, the D-Link cams that work with ST are not Zwave and I don't think the Samsung and Nest cams are either.
It's been a year, how is that integration going Netgear?
I doubt they're doing anything.
I keep hoping that these cameras will be integrated. I want to buy an Arlo Q but am sticking with just my 4 Arlo cams until either they become "smart" or I move to another system.
You can already unnoficially integrate the ST hub with the Arlo hub, you can configure ST via a smartapp to change the Modes on the Arlo hub based on if your ST hub is Away or Home.
Just google for AutoArlo and download the script from github.
Provide your login details in the app and it should connect.
Works perfectly.
Just require access to the Live Feeds now.
Awesome! Just got it setup and working...had to play around with it a bit to realize that you don't just type in the mode # but you actually type "mode0" or "mode1". Anyways, thanks for the heads up!
Thanks for the sharing of this. I had seen it on the ST forums. I'm looking for more integration so I can actually see the streams/images with ST because I use a smartapp called SmartTiles to control my system throughout my house and would like to be able to see the cameras through that interface.
That's interesting. What I would hope to be able to do is use the arlo movement detectors to trigger other events.
Say I have a camera detecting someone up my driveway, I'd want that information to tell ST to turn on the lights in the house if it is dark outside, maybe ring a chime, that way I don't need to duplicate movement detectors.
In order for ST or any SmartHome Appliance or Software to truly work with Arlo. Netgear needs to get moving and start making it that the Arlo can be SmartHome Protocol aware.
It needs to be able to communicate with most if not all of the protocols out there.
- ZWave
- ZigBee
- Insteon
- C-Bus
Just to name a few. Once they do that, then I will say that our Arlo's truly belong in a Smart Home Environment!
If you go to ifttt.com, you'll that it now supported and your smart things hub will be able to control it.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
