iOS Shortcuts to change mode
  • 1 Reply
  • 2068 Views
tupokmu3
I just want to create a simple shortcut to arm/disarm my cameras.
On Shortcuts, I tap "+" in Starter Shortcuts, select "Arlo Secure" from the list and it presents me a list where the only option is "Change Mode". I tap that and it brings a screen to configure the shortcut. Pls check the screenshot - what's that Location? No matter what I pick on that thing, when I run the shortcut it shows a popup saying "Location" with a Cancel button and nothing happens.
Best answers
  • ShayneS
    Hi @tupokmu3
    That option is referencing your location Name, under Locations and plans within your profile in the Arlo app. I believe by default, it's set as "home" and you can change the name. Also, if you have multiple locations added, you would be able to choose which location. So that name is reflecting the name of your current location created in the Arlo app. Hopefully that info helps.
ShayneS
Hi @tupokmu3
