Why is Base station offline
It would seem to be a display issue. Have you checked the status of the LED(s) on your base or hub? Have you rebooted the phone and/or force closed the app and cleared the app cache? WHat is shown when you use the web client on a computer (my.arlo.com)?
The led on base I blue.
have tried to reset the app and arlohub. Very weird.
but the cameras are working..
On my.Arlo I see the cameras online but no base hub 😤
Try rebooting your router and hub, in that order.
Do you see Library to view recordings or Feed? If the latter, the Dashboard won't show your hub but Devices will.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
