Hello.
I have an 8-camera, 2-base, Arlo Wire Free system. These have all been intergrated into Smartthings for a couple of years now. The cameras are always Armed, and the ST app controls what to do when motion is seen. Using the cameras as motion detectors, and using dedicated motion detectors, ST sends me a text message, and tells the affected camera to record for 30 seconds. This all worked great up until about two weeks ago. Now all I get are the text messages indicating that motion was seen. No video is recorded. I also cannot stream video in the ST app, but can turn off and on the camera, and see battery and motion status. I have removed and reinstalled the cameras into Smartthings. Twice. I have contacted Smartthings. They started a support ticket, but I have not heard anything back from them, despite several prompts from me. Any help here would be greatly appreciated.
Mike
Smartthings automation with Arlo is down. Samsung diagnosed and found it to be on Arlo's side.
Arlo if you guys are reading this, please fix!
I record to the Arlo cloud but use Smartthings integration for the motion triggers. I've just gone into both the Smartthings Classic and new Smartthings apps and, like you, I cannot view the stream. I suspect a change on the Arlo side of things with Arlo Smart being widely released recently. Please go to the bottom of the page and click "Contact Support" and follow through to opening a support ticket about this. I'll do the same. Hopefully a few tickets will get the situation sorted quicker
Hi @mike_pace
I haven't been able to view the videos in Smartthings for a long time now. I think they were considering making that feature a paid feature then after that it quit playing videos for me. So, you are no alone.
Brian
Same issue here and it started about 2 weeks ago for me as well. I will open a ticket, but wanted to chime in that you are not alone with this issue. I also suspect something on the Arlo end, as has worked for almost a year for me and it seems to have coincided with release of some of the new Arlo features. Tried restarting my base stations (I have 2), deleting and re-adding to ST, etc. No luck so far.
Hey @RobertRosal,
What problems are you specifically having with the integration of SmartThings and Arlo?
I started a support ticket with Arlo, but need to find the time to complete all of their troubleshooting steps, like removing and installing the base units and cameras again. I also started a support ticket with ST. They had me remove and re-integrate the cameras in the ST app. Still nothing. They are gong to elevate the ticket to level 2.
I don't think any of your (user) troubleshooting steps will resolve this for you (us) at this stage but you can go through the process if you want. I think it's the ST Classic app that says the URL for the stream is incorrect. Doubt that'll be anything that a user can fix. Keep us posted how you get on though
It also doesn't work in the new app but it doesn't give the URL error message in that
Smartthings is sending triggers for Arlo to start recording (shown in Smartthings notification screen), but the recordings never take place on the Arlo side. Started toward the end of November for me.
Called Samsung and they don't have a clue. Said this has to be something in the arlo credentials and opened a ticket.
@JessicaP wrote:
Hey @RobertRosal,
Hi Jessica, I recently noticed that automations that I set in SmartThings using motion sensors to activate recordings on an Arlo camera no longer works. I have two cameras that have been set that way for over a year and recently no longer work.
I have contacted Samsung SmartThings to diagnose and they have found that something has changed on Arlo's end and why it no longer works. They have told me to sumbit a ticket with you but unfortunately with my work schedule I have not had the time, so I am glad you caught my post.
If you can get this resolved would be great!
In my mind it has to be with a change that Arlo did. I have already did some trouble shooting with Samsung. What we have tried so far was to reset my sensors, replace the sensors with another, point the sensor to another camera, go into ide and see if all was correct.
I then did some trouble shooting with the Arlo and since I have an extra base I worked with that. Reset the base, reset the camera, nothing works! Since we are all having the same issue and when I think back when it started, it seemed to all start with the addition/changes of Arlo smart.
I started to have the very same problem with Arlo not recording and also changing my mode status from my Custom mode to disarmed.
It all started a week or two ago since Arlo added new features to Arlo Smart. I am paying for Arlo Smart.
Thank you guys for the advice. I deleted ST mode and works now. The problem getting ST to record from cameras or have just a feed dont work yet.
Thanks both of you for your prompt response.
Hi SantanderUSA,
When you say it is working now, what is working now? Does your sensor on Smartthings trigger a recording?
The issue with Arlo changing from a "custom mode" to "disarming" by itself got fixed when I deleted ST mode, but I still can't see live feed from cameras in ST classic app in my mobile (the only one I use), that did not get fixed... 😞
....and my ST motion sensor (zooZ) does not trigger the Arlo camera. Still testing.
That is what alot of us are experiencing.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
