VMB5000 Home Kit Stuck
  • 22 Replies
  • 7737 Views
  • 10 In Conversation
MrG95
Trying to connect hub to home kit. Stuck at connecting to bridge. Loads forever. I rebooted everything I can think of (hub, cameras, router, phone). I need help!
22 REPLIES 22
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
HaliaRanch
Having same issue
RHitchcock
I'm also unable to connect my SmartHub to HomeKit. I followed the instructions in https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-device-to-Apple-HomeKit. Trying to connect from the Home app, it gets stuck and eventually times out at "Connecting to Bridge" and says "Accessory Not Found." Trying to connect from Arlo Secure, it sits forever at "Discovering your device. Please wait."
How do I resolve this? I have the latest firmware. I've restarted everything. Is there any way for people to resolve this themselves?
Thank you!
RHitchcock,
stelchor
Hello,
I just purchased an Arlo Ultra 2 camera kit and the smarthub VMB5000r6 is unable to be added to Apple Home Kit. Using the Arlo Secure app, it is stuck at the Connecting ui. When trying to connect through the Apple Home App, it says that the accessory can not be used with home kit.
Can I please get some help? Thanks!
stelchor,
Japie52
Stuck at ”Connecting to Accessory”.   Rebooted VMB 5000.  Same result.
ShayneS
@Japie52
Can you bring your Smart Hub back online and I will reset your HomeKit token.
Japie52
Base station has been back on line for three days with no change.
Japie52
Still awaiting a token for my Smart hub.  As an aside, the QR code is never accepted when using the camera and I have to key in the numbers each time I try and connect.
ShayneS
@Japie52
Thank you
Japie52
Thanks.  All good now!
ShayneS
Perfect, let me know if you need anything else : )
PatrickDBO
Hello,
Same problem here whilst connecting new VMB5000.
Tried to reset everything. No luck.
Please help.
Patrick
Tayfam
I am having the same issue, could I have a HomeKit token? Thank you.
PatrickDBO, Tayfam
Tayfam
Thank you, I was able to connect the hub to HomeKit. Happy Holidays!
PatrickDBO
Thanks James.
it works!
Patrick
BarkA
Hello,
My configuration, Arlo Ultra 2  (x4) camera kit and the smarthub VMB5000r6 is unable to be added to Apple Home Kit. Using the Arlo Secure app, it is stuck at the Connecting ui. When trying to connect through the Apple Home App, it says that the accessory can not be used with home kit.
BarkA,
BarkA
TY James, everything seem okay now!
