- English
- Arlo Forum Discussions
- Partner Integrations
- Arlo Pro w/VMB4000r3 base station - HomeKit cant f...
Arlo Pro w/VMB4000r3 base station - HomeKit cant find devices
As the title says, I cannot get the HomeKit setup to work, its just sits and spins trying to discover devices. Nothing ever found. I have tried restarting and resetting with no luck. I would love to get this all setup on my HomeKit system. Any help or token reset would be greatly appreciated.
Thanks!
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thank you, James. I will let you know how it goes!
Hi, I have the same issue where when selecting the HomeKit setup page it is unable to find any devices. My iPhone is on the same network as the Hub. Everything else works without issue.
daleks0,
James/Arlo,
Thank you for resetting my token the first time. I had a network issue and to add this back to Apple HomeKit, Im afraid I need another token reset please.
Thank you again, happy new year!
Gustafa,
Thank you James! Ill check it out shortly.
Chase
AppleTV
31 -
Samsung SmartThings
83 -
Security System
