Dear all,
I'm facing "missing audio" issue when I use my Arlo Pro camera via Homekit (remote mode, no wifi), basically I can see the Image but not able to hear the audio.
all it works fine using the wifi connection or the official Arlo app.
Do someone faced the same issue? any suggestion that can solve the issue is welcome
ciao
Hi @Mar73
Have you tired to remove the camera from Homekit & re-add it?
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
done, waiting for a feedback.
thanks
@Mar73 Any news?
I have the same issue, but only with one (the only I own) Pro2 camera, all my 5 Pro cameras are fine and I can hear audio.
https://community.arlo.com/t5/Partner-Integrations/Pro2-HomeKit-no-audio/m-p/1726969
Regards.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
