Unable to share saved Arlo video on iPhone
  • 36 Replies
  • 12797 Views
  • 5 In Conversation
IDW
I have saved a video from the Arlo app on my iPhone- when I try to share it I get an error message
i have searched and seen that this error has been present for several years. Will there ever be a resolution?
thanks
BrookeN
Can you update the iPhone and see if the behavior is still seen?
36 REPLIES 36
Are you seeing the video when you look on icloud.com???
IDW
Hi
it uploads to iCloud fine and is available on other devices
I can share the copy on my iPad - but the original on the iPhone still has the error.
BrookeN
Are you still seeing this same behavior?
IDW
Hi
just tried again - same error
BrookeN
Is this a downloaded video or are you sharing it straight from the app? Are you seeing this with just that video or is it all videos?
IDW
Hi
its a picture downloaded from the app to the iPhone photos library.
i cannot share the picture using the iPhone share menu in the photos app.
videos work as expected.
BrookeN
On your iPhone try logging out of your iCloud and logging back in. And then try to share the video.
IDW
Hi
videos share fine - the problem is with the jpg images
logging in and out of iCloud makes no difference to that I’m afraid
IDW
I was mistaken at the start of the thread - I got the error trying to share an image
BrookeN
Is it all images? Or just that one particular image?
IDW
Hi - it’s all images, every time anything is saved..
thanks
BrookeN
All images even images that are not Arlo or only saved Arlo images?
IDW
No just the saved ones from the Arlo app
Are you using iOS?  If so, do you have space in iCloud?
IDW
Hi
yes it’s iOS and yes there is plenty of iCloud space
as I have said I’ve checked all candidate issues
the error is  simple to replicate - take a still from Arlo camera, save it using Arlo app then go to the photos app and try to share it in iMessage etc.
there is an error.
the problem is with the Arlo app - the jpg saved clearly has erroneous metadata (share examines the metadata). As I’ve also said - when I access the same picture on another device (ie it’s been uploaded to iCloud and downloaded) it can be shared (so the iCloud transfer has fixed the metadata) - it obviously doesn’t fix it on the original iPhone…
thanks
BrookeN
I am able to replicate this on my own iPhone. Let me look into this further and I will post an update soon.
IDW
Thanks very much
BrookeN
You can share the video/picture straight from he Arlo app as a work around for now.
IDW
Thanks for the update …
Cdgee
This is still an issue. Was a fix shared?
Is there enough storage in your iCloud account to store the video?
Cdgee
It’s an image not a video. But yes. I’m using 80 gb on 2 tb of room
Cdgee
At present I either share through app or take screen grab and share. But it’d be nice to be able to share as was done before. I think I lost functionality around time OP posted ^^
I'm a bit confused on the details of what you are doing.
This works on my iphone (likely several variations would also work)
  1. download the recording to the phone from the Arlo app.  After downloading it appears in my iCloud account as well as being on the iphone
  2. select the video in the camera app
  3. email the video.
This is on an iPhone 12 mini running iOS 17.4.
