I am not able to add my Arlo to Apple HomeKit, can you assist?
Best Kåre
Thank you
Hi can you please reset token for my arlo base station again? I had to delete from homekit and readd and now my basestatiom
cant discover homekit again. Is there a permanent fiz for
this issue other than asking for token resets?
basestation serial is
4R05827YA068E
Dcljunkmail,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Hi ,
i have the same issue it is not discoverable and can’t be added to homekit, can you reset mu token as well sn 4R057B7JA11BF
thanks
Hi,
it is still not working , can’t be discovered as a bridge for home kit, can you please reset the token again?
I have went ahead and reset that token again. Before setting up the HomeKit, uninstall and reinstall the app, reboot the base station and then go ahead and try to set up the HomeKit.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
