Token reset request for apple homekit
  • 8 Replies
  • 4857 Views
  • 5 In Conversation
Rendc
Hello, my Arlo base stopped working with HomeKit. Could I get a token reset please? Thanks in advance.
8 REPLIES 8
ShayneS
@Rendc
I have reset your HomeKit token, Please reboot your Base Station or Smart Hub and try again. See your base is offline so it's possible we may need to bring it back online then try the reset again.
Thank you
DaveArlo27
Could I request a token reset for my Arlo camera, I tried restarting and trying to connect but can't - and need it reset again, not sure why it didn't do it - appreciate your help Arlo Team.
Safer
Hi, I have a similar issue after I had to remove the Arlo hub from homekit.  Now I can’t add it again. HomeKit complains that the hub is already in use in another home and HomeKit in the Arlo app is just stuck in the search mode.
ShayneS
@DaveArlo27 @Safer I have reset your HomeKit token, Please reboot your Base Station or Smart Hub and try again.
Thank you
Safer
Hi, I rebooted multiple times but my problem remains. Homekit says that the product/hub/bridge is already in use in another home. The Arlo app just gets stuck on the Identifying unit step in Homekit.
BrookeN
I am going to reset the token again. But before setting it up, uninstall and reinstall the app, reboot the base station and then try to set it up. Please let me know how that goes.
Safer
I followed your instruction but the problem remains. What to do next?
BrookeN
I have reset the token again. You will have to do a reset of the base station and re-add the cameras to it. And then attempt to add the HomeKit.
