Unable to add Apple Homekit to VMB4000
  • 4 Replies
  • 3436 Views
ehlersg
I am unable to add the Apple Home Kit to my VMB4000 base station. I'm following Article ID: 000062279. I don't have a setup code on my base station so am using the setup an Arlo device without a setup code instructions.
In step 4, the Homekit option is not available within the app.
1. Launch the Arlo Secure app on your Apple device.
2. Tap Settings > My Devices.
3. Select an Arlo Base Station.
4.Tap HomeKit.
I have several Homekit devices working on my network. The Arlo Hub is plugged into the same network via an Ethernet connection to my router.
Any suggestions.
ehlersg
That allowed me to see the Homekit option. When attempting to add the Homekit I receive the error "Unable to Add Accessory. Accessory is out of Compliance. I powered down the base station and restarted and now everything works. Thank you.
ShayneS
I have reset your HomeKit token. Can you remove and reinstall the Arlo app and check again.
ehlersg
klphan870
Hi - can you please reset my HomeKit token as well?  I cannot connect my Arlo hub to my HomeKit.  Thank you!
klphan870,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
