- English
- Arlo Forum Discussions
- Partner Integrations
- Ultra 2 SmartHub - VMB5000 will not connect to App...
Ultra 2 SmartHub - VMB5000 will not connect to Apple HomeKit
I'm unable to connect my Ultra 2 SmartHub to Apple HomeKit and require a Token Reset.
Hardware: VMB5000r6
Firmware: 1.21.1.0_1431_9611cf3
Thanks in advance for your assistance.
Respectfully, - R.S.
Thank you
Thank you for resetting the token, but I'm still unable to connect. I restarted the hub multiple times and even reset it and the results are the same. I've been able to connect it in the past so I know it’s possible. Are there any other resets or adjustments you can apply? Or maybe apply another token reset just in case?
Thanks for your continued support.
Respectfully, -RS
I have reset your HomeKit token, you can also try removing and reinstalling the Arlo app as well as reboot your base station again.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
