Hi
same as the others. Can I please have my token reset for my base station? I’m stuck at “discovering devices”
@Dustbunz your token has been reset. You will need to reboot the smarthub/base station.
Hi
For me the same.. can i have a reset please?
keep seeing : discovering devices..
thx!
dylanthology,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Can you reset mine again please? Still having the same issue after a factory reset.
Hello, can I also have my token reset. Stuck on discovering screen in Homekit setup section. Thanks,
Bugrat,
AppleTV
33 -
Samsung SmartThings
90 -
Security System
