Would you be able to send a token reset to the affected base station please? (VMB4540r3 model)
Thanks.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I am having the exact same issue with my base station. Can I request a token reset as well?
Hansel
Hlopezz02,
Hi James,
I am also having the same issue with my base station. Can I request a token reset as well?
spouwer,
I also am stuck on "discovering your device, please wait". I tried power cycling bridge but didn't fix it. I think I need a token reset as well. Thank you!
joellarosa,
That didn't fix it. Still gets stuck on "discovering your device". It used to work in HomeKit but stopped working. I deleted it from Home app a few days ago to try and set it up again but no luck. Any other ideas to get HomeKit working again?
Actually that did it! I just tried again and it worked this time. Thank you for your help!
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
