Stuck on “Discovering your device. Please wait.” when trying to add cameras to HomeKit
  • 8 Replies
  • 3990 Views
greggt94
Setup all my cameras about a month ago and just setup the SmartHub so I can add everything to HomeKit. SmartHub connects just fine but when trying to add my cameras it just hangs
8 REPLIES 8
ShayneS
Thank you
greggt94
I’m able to add the Base Station but the cameras still don’t show up in the Home App
ShayneS
@greggt94 The devices need to be paired to the Base station for them to populate to HomeKit.
You can find more info here: https://kb.arlo.com/000063184
greggt94
So basically I should just remove all the cameras and re-add them now that the base station is setup?
If you want homekit, that is what you need to do.
ShayneS
@greggt94
The devices are required to be connected to a Smart Hub or Base Station to utilize Homekit. If connected directly to your router/WIFI they will not be available as you are seeing.
Toxiicscorpiio8
Can I get a reset token as well
ShayneS
@Toxiicscorpiio8
You sure can, all done. Please reboot your Base Station or Smart Hub and try again.
