- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Solution for no Auto Home/Away (Uses SmartThin...
So Arlo and SmartThings aren't currently integrated together yet, and Arlo doesn't offer an auto away or home feature so I had to come up with a way to automate Arlo into the SmartThings ecosystem. If anyone is currently using Arlo for there home monitoring this should work for the time being.
1. Connect Arlo to a compatible SmartThings plug.
2. Arm Arlo to "All Motion On"
3. Set the plug to turn On when Away
4. Set the plug to turn off when Home
5. Set the plug to turn off when Morning
6. Set the plug to turn on when Night
This allows me to have Arlo turn on and off based on the presence of who's how and gone. So far its working fantastic.
If I read you right, your using the PLUG to unpower Arlo base and then re-power it again later??
Only one possible problem I know of... sometimes when the Arlo base looses power the cameras can become "un connected" to the base unit. Tho the base unit will come back automaticly , if this happens the cameras will not. The only solution is to re-sync the cameras to the base.
Also, TMK, the cameras will draw more power when the base goes down as they attempt to ping the base unit more, maybe shorter battery life
This sounds great... any idea on the battery life? How long have you run it this way?
I've just started about 4 days ago, and thus far I've had zero issues.
There is now a better way! 😉
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
