Smartthings Mode
My arlo base station has Armed, Disarmed, Scheduled, Geofencing Modes nut not Smartthings mode.
Your earlier post made it sound like you were seeing that mode.
Here's more info on smarthings:
My Arlo is currently linked to Smartthings and I don't have Smartthings mode in my Arlo Base Station. If I unlink Smartthings and then relink would Smartthings mode show up?
There is no "Smartthings mode" in the base station,
The instructions for integrating your cameras into SmartThings are in the link I posted earlier.
From what I understand they did away with the smartthings mode. The integration is pretty much broken and rendered useless. There really is no integration any more to smartthings, as you cannot do anything with the cameras through the "integration" that currently exists. Yet Arlo continues to market that they "integrate" or "works with" smartthings.
It would be nice to create routines within smartthings and utilize all of the functionality of the cameras. For instance Vehicle or Person detected at night, turn on a virtual outlet that will make an announcement on a certain Amazon Echo Device. Currently you would need to create a bunch of virtual devices, and utilize IFTTT, and Amazon to get it to work.
There used to be an absolutely amazing integration between the two platforms, it was great, until it broke.
AFAIK, there never was a "smartthings mode" in the Arlo app.
Though it's clear that overall Arlo's partner integration has slipped.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
