- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Apple HomeKit "Requesting HomeKit Info..." Err...
Ok. So after a couple of reboots of everything it looks as if the camera is now added to and showing up in the Home App. Only issue is that it doesn’t stream. Shows up as “No response” in the Home App. Solution?
Same issue… “not responding”
Hi dsaponaro and Onavarro89,
Because the issue is not related with the other thread, I have moved your threads into a new one.
Are you able to live stream your cameras through the Arlo iOS app or on the web client on your computer?
Yes, app works fine.
Just on HomeKit it shows up but “no response”
If the Arlo app is working well but not on the Home app, you may need to refer to Apple Support Team. You can also try referring to this Apple discussion thread to see if it may resolve your issue: HomeKit accessories not responding - Apple Community
Removed it from HomeKit and tried to set it up again and it isn’t being discovered… can you please reset my camera to be able to set it up
Hi Onavarro89,
I've sent a token reset request to your Arlo Baby. Please power cycle your Arlo Baby and wait until it comes back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
AppleTV
31 -
Samsung SmartThings
82 -
Security System
