- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Schedule Arlo wire-free independently of motio...
Is there any way to schedule the cameras to record for, let's say 1 minute every day at 8:00 am, without relying on motion detection.
I mean, all cameras would record wether or not motion is detected.
No... not as the program currently is.
OK, thank you.
That's too bad, I think it would be a cool feature with minor development cost
z00b wrote:Is there any way to schedule the cameras to record for, let's say 1 minute every day at 8:00 am, without relying on motion detection.
Yes this can easily be done with an ifttt recipe.
Register with them and use the "Date and Time" channel and the "Arlo" channel.
It would be if "Date and Time" = this, then "Arlo" Start recording.
I've created a few recipes and they seem to work fine.
So one recipe I created will start recording on a camera when a Wemo Switch has been activated. So whenever that Light turns on, because of a motion sensor I have out front, that particular camera starts recording.
It would be easier if Arlo was actually compatible to zwave devices, it would have been easy to just say if the motion sensor activates start recording. Oh well, I got it working in a round about way.
Wow, awesome.
I got it to work in like 5 minutes.
And I did not know about IFFT, it's a pretty neat service !
Thanks !
Good outside the box thinking... I forgot about the IFTTT
You're welcome!
RobertRosal wrote:
Yes this can easily be done with an ifttt recipe. Register with them and use the "Date and Time" channel and the "Arlo" channel. It would be if "Date and Time" = this, then "Arlo" Start recording.
Can this be done for snapshots rather than video recordings? It would be nice to be able to do time lapse rather than video to monitor some situations.
hokeysmoke wrote:
RobertRosal wrote:Yes this can easily be done with an ifttt recipe. Register with them and use the "Date and Time" channel and the "Arlo" channel. It would be if "Date and Time" = this, then "Arlo" Start recording.
I did not see that ability on Arlo's channel, hopefully they will add that in the future.
Thanks Tom!
AppleTV
32 -
Samsung SmartThings
84 -
Security System
