Hi
i couldn’t add my new base station to HomeKit. “Unable to add accessory” error prompted. Would you please help to reset my base station HomeKit token? Many thanks
Thank you
lt works now
have the same problem. Can you please reset my token for HomeKit aswell. Tried all the workarounds already.
Am I able to reset the token by myself?
auwi,
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
I've just found this thread after having an issue with adding my Arlo Base Station to HomeKit. It says it is already added but does not show up in Apple Home. Can you reset my token too please as this seems to have worked for other commenters?
Thanks.
Hi @yakuza965 I have reset your HomeKit token, Please reboot your Base Station or Smart Hub and try again.
Thank you
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
